It is currently Sun Nov 18, 2018 1:59 am
 Page 1 of 1 [ 8 posts ]
 Post subject: Need a tactrix!
Unread postPosted: Sat Oct 13, 2012 10:56 pm
Hey all,
Just got a WRX and it's throwing the dreaded P0447 (evap leak) code. Car runs fine and after having the PO replace the gas cap and filler neck, and checking the vac lines (including a spray with carb cleaner to check for leaks), no luck. So, I was wondering if anyone could help me clear it for good using a Tactrix cable (or something similar). I'd be happy to pay someone for their time, let me know if you're interested.
I'm located in Watertown, NY. Thanks! :D
 Post subject: Re: Need a tactrix!
Unread postPosted: Sun Oct 14, 2012 5:33 pm
Bump
Unread postPosted: Mon Oct 15, 2012 5:42 am
Bump
Unread postPosted: Mon Oct 15, 2012 8:37 am
You can clear it with a regular code reader, most parts stores will let you borrow one.
'07 Audi RS4
'01 Impreza 2.5RS
'05 4Runner SE V8
'97 Legacy GT/WRX - Sold
Unread postPosted: Mon Oct 15, 2012 9:34 am
Ive got a regular code reader.issue is that doing this will reset all of your monitors to "not ready". Your cel will keep coming back and you wont be able to pass emissions. The tactrix lets you get around all of that by forcing readiness and permanently shutting off the code(s).
Unread postPosted: Mon Oct 15, 2012 9:49 am
xxBrun0xx wrote:
...clear it for good...
I think this is the trick to it. :wi:
Unread postPosted: Mon Oct 15, 2012 11:45 am
If you want to come down to Syracuse/Marcellus, I have one that you can use
Unread postPosted: Mon Oct 15, 2012 12:49 pm
Yeah, I can do that. How late are you open?
Users browsing this forum: No registered users and 3 guests
