It is currently Wed Oct 24, 2018 2:09 am
 Page 1 of 1 [ 2 posts ]
 Post subject: Trans/clutch problem
Unread postPosted: Fri Dec 20, 2013 12:06 am
Subie Driver
Helping a buddy with his 02 wrx. It's been swap, chop, hack and put back together. The other day, we were driving into town he lost his clutch pedal. Went to the floor and never came back up. Pulled into a parking lot and it smelt like the clutch was burning. Killed the car, towed it home. Pulled the trans and found the clutch itself was good. however. See pictures as to what happened next.
I've never dealt with a hydraulic clutch before. I know there is a push & pull systems out there. I'm at a lose of words on what to do next. The actual housing is leaking fluid near the bottom as if it was lubing the bearing. Still don't have a clutch pedal. There is metal shaving in the housing.
1) not suppose to leak fluid out, right?
2) Is that bearing suppose to come off?
3)Is it possible to just change the bearing?
Current spec's:
07 STI trans
Competition stage 4 clutch
 Post subject: Re: Trans/clutch problem
Unread postPosted: Fri Dec 20, 2013 10:08 am
tranny lube party host
It looks to me like that car has been modified to have a hydraulic throwout bearing, as opposed to the stock slave cylinder arrangement. That's a much better design, but you end up with a much larger seal, which is likely leaking now. The seal may be end-user replacable, but you'd need to find out what brand throwout bearing that is to have any chance of finding out what seal to get to replace it.
Scott Newton
CNY SCCA Solo Chair
#159 in whatever the class du jour is
Users browsing this forum: No registered users and 5 guests
